bspeth
- Aug 30, 2013
- 756
I was replacing my ujoints and I couldn't get the c-clips to seat properly. Pressed in one side and set the clip which left not quite enough room for the other c-clip.While tapping one side over the other clip would come un seated.I struggled with this for a while until I noticed a little gear lube coming out from around the bearing carrier seal.Is it likely that I messed up the seal with all the tapping on the yoke while the drive was in the bench? It was pressure tested prior to the ujoint work.My plan is to drain the drive and re pressure test it although Im sure it is leaking. Do you think it is a simple case of resealing the upper,or do you think I did damage to the yoke itself?
