Engine: Mercruiser 4.3L Reman
I purchased a remanufactured engine online (I know...first mistake) and installed it onto my boat. Everything worked fine until about 15 hours of run time. I was coming off of plane and just as I got to idle a loud, rhythmic knock could be heard from the engine. I increased the RPMs with the boat out of gear and, not surprisingly, the knock followed right along. Rather than tear the engine apart to determine the problem and risk destroying any evidence that the engine had a defect, I pulled the engine from the boat and sent it back to the remanufacturing shop from which I purchased it. The shop pulled it apart and said the only problem they found was there was water in one of the cylinders and told me that my risers and/or manifolds were bad. I had him take some pictures and send them to me and it's clear there was water in four of the six cylinders (pictures are below). The pictures that shows just one cylinder rusted also appears to show a leak path across the head gasket. I separated my risers and manifolds for a look but couldn't find any evidence indicating that's where the water came in (pictures of those are below). So, do these pictures indicate the water came from the risers/manifolds? I'm surprised the engine was even running with water in four cylinders.
