Pulled the outdrive off my Mercruiser 470 to determine if noise was from engine or outdrive. As soon as it separated, rusty water ran out of the u-joint bellows. Ran it with outdrive off with hose water. No "clacking" noise. As soon as I saw the rusty water I felt pretty sure it was an outdrive noise. What I found was the gimbal bearing was trashed. It has about 1/16" slop when I stick two fingers in and turn and wiggle it. Of course the u-joints looked like they were covered with mud, due to, I assume, rust sticking to the grease. The 'clackity' sound I was hearing wasn't a steady 'growl' like I would think a trashed bearing would sound, so I thought the u-joints would be trashed too. I know you can't tell by 'feel', but they feel smooth with no play. Question is, is it probable u-joints are trashed too? How do I tell if they are trashed? I will put a new seawater impeller unit in, but is there anything else I should check for, noise or otherwise, while I have it down? Thanks much.
