I have a similar situation but I didn't want to hijack pnhigg's post.
I too had water laying in my u-joint bellows. All three bellows need replacement due to cracking.
I just want to make sure I find the exact reason for the presence of water.
Would there be any chance that water can enter through the shift shaft? I assume there is an upper and lower seal where the shaft passes through the upper and lower walls of the exhaust chamber. If so, the upper seal just looks like a clump of corroded junk.
I hope I'm explaining this correctly. I'll try to post a pic.
