Dave 200 SSE
- Oct 14, 2014
- 5
I bought a 2001 Chaparral with 5.0 carb. The first thing I did is a complete tune up, plugs ,wires , cap & rotor, ignition mod in distributor , rebuilt the carb and checked the timing on it. I have had it running this summer but the problem I'm having with it is, # 3 cylinder spark plug fouls out with dry black soot. I have checked for spark on the cylinder and have it. My question to that is, would I have a bad set of lifters and cam shaft or something going wrong with the coil, or bad valve guides? I have readjusted the rocker arms to make sure they are properly set. Kind of lost to what could be the problem. Also did a leak down test on all cylinder, they all are good! Any suggestion would be Greatly appreciated ! Thank you for your time! Dave
