Engine Temp Rises/Overheats at Idle, Cools to Normal Temps while Moving...?
jts4486
Thank you all again for the help correctly diagnosing the bad ground wire issue from my previous thread. Hopefully this issue is similarly easy to diagnose and fix.
As mentioned in the thread topic, my engine temperature rises/overheats at idle both in the driveway and in the water but cools to normal operating temps while moving. The boat had sat for 3 years prior to me buying it this summer. My research points to impeller as it sounds like sitting is not good for them.
I am guessing the impeller needs replacing. Does a bad impeller cause the issue I'm experiencing? Other possible causes or things to check?
Thank you in advance!
Ayuh,.... The impeller is Always the 1st place to look, in any overheat situation,....
thumpar
The impeller should be replaced at least every other year. I would get the whole kit with the housing and everything since you don't know the history.
achris
More fish than mountain goat
Have a look at my video up in the sticky section and you'll have an idea of what to look for once you start getting into the pump...
Chris....
NHGuy
Mine did that at one point when I had a tired impeller.
achris
Yep, tired impeller can't pump enough water at low speed ('displacement' mode), but once it's running a bit quicker (into 'centrifugal' mode) it pumps just fine...
tank1949
Full kit is on order. Thanks again! You guys are top shelf!
Pull hoses at risers/stat housing and see if passing water. Your cir pump may be worned. I had seals in one only a year old that went bad.
888
check balls...stretch the springs or replace
four winns 214
I had a similar situation after a Merc authorized shop installed a new impeller. The young, inexperienced and unsupervised tech did not reinstall the water tube properly after replacing the impeller. Not enough water was getting through to the engine at low RPM, but enough made it at higher RPM. Unlikely your problem, but I mention it for those readers who run into overheating problems after impeller replacement.
tank1949
That is why I DON'T let any person work on mine that I don't know for a long time.
achris
Ah, we have another certified Merc mechanic in our fold, excellent. We need all the qualified help we can get here... Thanks for putting your hand up as an experienced tech. Now, get to work. :D
Chris...... ;)
tank1949
Chris...... ;)
Just yelled a lot of "aw-****" then solved it.
