jayhanig
Master Chief Petty Officer
- Jun 27, 2010
- 836
I've got an intermittent problem with my Mercruiser 3.0 not wanting to crank when I turn the key. (I've read the sticky). To cut to the chase, I hear a click at the engine but I have to keep cycling the key a few times until it decides it wants to turn over. Once it does start cranking, it cranks strongly. The starter is only a couple of years old.
The sticky suggested, among other things, that I might get by out on the water by just jumping the terminals A and B. I'm usually by myself, so it might be helpful if I fashioned a jumper cable with alligator clips. Good idea? Bad idea? How heavy does the wire need to be? I figure it only needs to be about 6 inches long to be easy to manipulate with my bear paws.
I have vague memories of doing something similar in my car years ago using a screwdriver, accompanied by big sparks. With the car ignition turned to ON, the starter would turn over as long as I had the screwdriver touching both terminals. That makes me wonder what would happen with this brainstorm of mine on the boat. I could tie a 6 foot string on the wire so I could just pull the wire loose from my helm position once the engine starts. Not very elegant but it beats swimming back to the marina. Your thoughts?
Thanks in advance, gentlemen.
