First time with this engine, Merc with 3 point drain system
Problem-It's to easy, I feel I must have missed something, I'm used to pulling plugs from block, pulling hoses etc.
I removed the four blue plugs like manual told me to do, had plenty of water come out, then reinstalled plugs, dumped a gallon of rv antifreeze down tstat housing, removed plugs again to check color-which was pink, reinstalled plugs and dumped 2 more gallons in it, as added protection
Lower unit-Bravo 3, used an old pump up garden sprayer to pump the 3+ quarts of lube in it. Worked like a champ!, my plastic screw in fitting and hose off my quart pump adapted easily to my sprayer.
