My engine bogs when hitting full throttle out of the hole. It runs fine other than that. The carb has never been touched in 17 years but only 200 hrs.
I'm thinking about having the carb rebuilt ( or at least replacing the accelerator pump) or replacing the Weber with an Edelbrock 1410.
The rebuild is probably $200-250 and a new carb is $400.
My question is do I have to change the jets on the Edelbrock 1410 to match the jets on the Weber or is it plug and play? Also, any other tuning needed for the new 1410?
The jets on the Weber are Primary .098 and Secondary .092. The Edelbrock 1410 jets are Primary .113 and Secondary .107
Thanks,
Thanks,
