82 Glasply
- Sep 13, 2014
- 6
Hello! First off, thanks for all the great advice, info., and tutorials here. So, just got this 1982 Glasply in very clean shape. Only problem is the Mercruiser refuses to fire / start / run. The carb it came with was dry, so I took apart the fuel pump, cleaned the diaphragm and filter looked good, so - re-assembled, reinstalled. Carb replaced with a pro-rebuilt. Now I have fuel streaming into the barrels.
Spark appears strong at all 4 new spark plugs. I sanded points and cap contacts anyway. The coil seemed to check out except for the voltage drop to 4-9V Across positive terminal to ground with key in on position. Coil replaced, new coil tests perfectly. Install of Ignitor 2 electronic ignition and Flame thrower 2 coil pending.
Oil looks fresh, no sign of water or fuel contamination. Oil change pending.
Compression is 140, 130, 130, 135 on 1-4 in that order Firing order, rotor position, and wire placement confirmed with #1 at TDC and tried at 180'. Pistons look clean from what I could see. Valve rockers look clean with same fresh, uncontaminated looking oil coating.
So, my question is: Why does the carb regurgitate air-fuel mixture when cranking with occasional back firing when primed with either fuel or starter fluid?
I suspect a vacuum issue. How do I test for vacuum?
Thanks in advance!
Thanks in advance!
