pontosquantos
- Oct 25, 2013
- 37
I have a1986 Rinker fiesta vee 250 with a mercruiser 260, cannot locate serial #. alpha one se106 leg. this is a close water cooled. it wasn't running good at after the first run of the season, so I started to change the standard parts. this is what has been done so far:
rebuilt Rochester quadrajet carburetor, new plugs, wires, coil, distributor cap, rotor, fuel pump, carburetor anti- siphon valve and PCV valve. boat still won't reach wide open throttle. it will max out at about 2800 rpm under load. I can reach 4800 rpm in neutral .figured maybe blocked exhaust possibly lodged a flapper. Checked them and they are fine. figure that I will run out the season cruising at low speed, (not a biggie saves fuel..) I will go over it better in the winter when i have it out of the water. I went on a four hour trip last weekend and the boat ran great chugging along 1500rpm. on my way back the boat stalled as if the ignition was shut off. I pulled the hatch and could see that the back of the intake manifold was covered in oil. I didn't bother to try a restart, just limped back in on my kicker. Seems to me that my PCV valve failed and over pressured the crank case. once I started to investigate I discovered that when the mechanics replaced my electric fuel pump with a mechanical pump, they took the hose for my PCV valve and moved it from the intake manifold to the flame arrestor. they put a plug in the manifold where the hose went to before. when I look at this it does not seem right, there is a PCV valve on one valve cover attached to the flame arrestor and no breather on the other valve cover. how would this work? should there be a breather on the other valve cover? and would this cause me to not get the rpm's I am looking for?
thanks for your advise in advance
