Speakrdude
Ensign
- Feb 25, 2004
- 942
I am rebuilding the above referenced engine to drop in a 23' Maxum open bow with a Bravo 1.
My intentions are to install an electric (Airtex-Marine) fuel pump and simply "Block-off" the raw-water-pump mounted, mechanical fuel pump.
Anything wrong in my thinking? I intend on connecting the fuel pump through the low oil psi switch.
Does there need to be any delay timer installed for the initial key-on for the fuel pump to run for a few seconds with -0- oil psi or will simply cranking the engine to build oil psi suffice?
Any pointers are always welcome!
