fromcarsToboats
- Jul 10, 2013
- 46
i have a alpha gen 1 out drive that i need to reinstall. do i install bellows on gimbal first? anything you can give me would be helpful.
Just follow the outdrive manual and be very careful about clamp placement.
is very improtant. that hose is a plane bummer to put on proper w/o some kinda treatment..If you are doing the water hose also you can put the end in a pot of boiling water (not touching the bottom) and it will slide on like butter.
