I have a 1999 4.3L with ALPHA 1 GEN 2 everything points to LH engine rotation. So I engaged reverse as instructed by the manual and pulled the stern drive off, it resisted a bit and there was a twang when it came off but came off anyway, engine out engine in, realigned with tool, hunkered down, alignment still good. Try to put the stern drive back and it wont go the last inch because with the control in reverse, the gear change cam is at an acute angle, (not parallel to the drive shaft as I would have expected) so the lower shift lever will not go into it.To get the cam straight I would have to put the control into forward gear.
I just don't get it..what am I missing here? Have I broken something when I pulled the leg?
My prop by the way looking from the rear turns clock wise to go forward, if this helps?
