Outdrive shaft seals
trailshredder
I bought the gasket set (Seals) to mount my 89 bravo drive. I saw an illustration that showed the 2 O-rings at the base of the u-joint drive shaft and showed one o-ring also at the base of the splines on the shaft. There is no groove on my drive for this o-ring. Does it go on there but not in a groove or is this o-ring near the spline for a different bravo drive?
Bt Doctur
no, that 3rd O ring is for the input shaft that has the groove.
