tremblaylaroue
- Aug 11, 2013
- 7
Hi,
My boat is a Maxum 1996 with a Mercruiser 3.0 LX engine. I bought it abot a year ago.
Since I got it, engine i starting easily and is running smooth but it is noisy (some knocking sound) and is also burning oil for few seconds after a cold start.
I did regular maintenance and tried to locate and fix this annoying noise (spark plugs, oil, ignition timing adjustment, valve rockers adjustment) but didn't find anything wrong and engie is still noisy (knocking noise like a diesel engine).
Today I checked the cylinders compression: After 4 compression strokes, engine warm, with carb throttle open, I got 175 psi on #1, 170 psi on #2, 195 psi on #3 and 180 psi on #4. I checked my compression gage and it is good. From what I've found the normal compression should be around 145 psi, I'm wondering why I got these higher compression readings and if it could be related to this diesel engine sound it has?
I also checked again valve rockers adjustment (engine running at idle, unscrewed adj nuts until rockers knocks, screwed in 3/4 turn. Engine noise is still the same and it's not related to valve train.
I also unplugged sparkplug wires one by one while engine was running to see if the noise was related to one piston but it looks like it isn't.
I also checked engine oil pressure using a pressure gage directly on the engine:34 psi at 750 rpm, 40 psi at 2000 rpm
I'm wandering what to do or to check next? Should I take the engine out to check cylinders, pistons, connecting rods and crankshaft?
Thanks so much for any help you can provide.
Dany
Dany
