She sank last weekend for about an hour and we got her drained etc
Changed the oil and flushed it until it was bone dry.
Checked two spark plugs for water and was good to go
Turned her over and got Hydro lock as the other two cylinders were full of water (should have checked all) Turned her over until there was no more water coming out (it shot 30' in the air impressive)
Changed the oil yet again since the water from the cylinders drained down.
Checked and had no spark
Left for a weeke replaced coil and oil filter and then put some fule down the carb and she tried to run
We drained the fuel tank and put new fule and Poof she fired up and was running smoother than she had before...... for about 4 minutes then all of sudden white liquid started gettting shot out the air breather above the carb and out the exhaust in to the lake!!! Checked the dip stick and clean water came flowing out the top of the dip stick tube.
SHut her down and pulled her out of the lake
The only thing I can think of that might have caused issues was that the stern drive was down when it sank and the perssure may have done some stress on something. It definatley appears as though the coolant system is pumping in to the engine some how
Hope fully there is another possible cause other than a cracked block cause that would suck goat balls
Any help please
Any help please
