Hey guys, new guy here. I rebuilt my carb and now my 99 Regal 1800 LSR will bog when cruising past no wake and will bog and stall upon acceleration. I took her out after the rebuild and it acted up at first but then ran fine, but today it was bogging and stalling all day.
I've been doing research and it sounds like my accelerator pump. The rebuild kit came with a check ball but I didn't see one when I took the carb apart.
My question is if the missing check ball could be causing this trouble, or maybe I installed the accelerator pump backwards or something, or maybe the old check ball is jammed somewhere. I am unsure if it gets sucked into a hole or if it's always visible after removing the accelerator pump. Any help would be appreciated. Thanks guys!
