Biglou0212
- Jul 27, 2014
- 4
Need any help figuring this out. 78 stern craft ran great one time after father in law purchased it. Quit on him in the middle of the lake, right as it was trimming out, thinking due to old gas. Cleaned fuel filters which had hard deposits boat would not turn over. Back on land now and returned all wiring back to original. Replaced starter and ign coil, ign switch starter fuel pump. Got it to fire up in the driveway and it sounds like it has a miss. Will hit 70 on tac Did plugs and checked rotor and cap. Had light carbon deposits which I used dremel to polish. Did compression test on all cylinders and they all read between 115 and 123 psi. Rebuilt carb Get boat back on water and now it won't go over 30 on the tac full throttle. Need to know what else to try or check. Any help appreciated.
