mxracer342
- Jul 14, 2014
- 9
Ok I'm a fairly new boat owner and I'm having a intermittent issue that's got me stumped. I've bought a 1994 Bryant 180 with a 4.3 mercruiser. The boat stays and runs fine. The problem is in heavy waves at just about any speed when it's bouncing boat and down will occasionally cut out like it's not getting fuel. Twice it's done so bad that the engine completely died. The first time it fired right back up the second time it would start die so after the 4th time that happened i let sit a minute then fired up. I was thinking carb issues but ice read several posts that say something about oil pressure sensor causing it. My question would be if it is oil pressure sensor would it not just go bad or could it cause an intermittent problem like this and if not could anyone on here me ideas what to check.I talked to my mechanic but can't afford pay him hundreds dollars to find a problem i possibly could fix myself. Any advise would be greatly appreciated!
