I recently removed my gimbal bearing and though there is a grease fitting on the housing, I noticed the bearing itself was a curvedrounded steel with no access to the inner bearing. It also seems the new one i bought had the hole in the bearing housing but no access to the inner bearing.
After installing the new bearing (Slots out) I tried greasing the bearing and noticed the grease coming out the back side. I made sure the hole was lined up with the grease port. And, I was not certain it was all the way in as it seems to stick out about a 32nd to 16th or so further than what I remember. I jsut couldn't get it to go any further and I did not feel any gap on the backside.
So question is, is it possible I have non greasable and would it hurt to try and spin the bearing to remove and double check? If I spin it will it pull out by hand?
thanks.
1999 Sea Ray 190
mercruiser 4.3l mpi
Alpha One Gen II
thanks.
1999 Sea Ray 190
mercruiser 4.3l mpi
Alpha One Gen II
