mtkbuckeyefan
- Jun 22, 2014
- 2
Glad to have found this forum and hope that you will be able to figure out my problem.
My first boat...... and I am NOT the biggest mechanic out there so hoping this MIGHT be something easy to fix.
I bought a 1982 Sun Runner 165 Runabout with a Mercruiser 140 motor on it. The HID number on the boat is XUE20164M82. When I purchased the boat reverse was working just fine. Went out on a trip with it and when we went to trailer it I placed the boat in reverse to back up so I could align myself with the trailer. Instantly at that point the boat jerked forward and will no longer go in reverse. When you actually put the shifter in reverse the boat goes FORWARD. So the boat goes forward in both positions on the shifter. When boat is idling....the prop still spins at a slow rate. Enough that when in the water it will propel you forward but at a slow speed. I do not have neutral unless I turn off the boat and then turn it back on without placing it in any forward or reverse position on the shifter. When I run the boat with the ear muffs on it I can see that no matter which direction I put the shifter on the boat in, the propeller moves in the same direction confirming that there is no reverse but forward propulsion in either shift position.
Now the funny thing.....I was out in it yesterday and for a VERY brief minute....I had REVERSE. I actually kept the boat in reverse for a few yards to know that it was working. When I put it into neutral and then back into reverse the thing went forward again. So, I lost reverse again. I know the boat works in reverse. It is just having trouble finding it....
Can anyone walk me through a fix with this? Does this sound like an easy fix for someone who isn't the most mechanically inclined? (I know that many of you will say that owning a boat one should know how to fix it.....This is my first attempt at boat ownership and hopefully I will one day be able help someone out as hopefully one of you will help me out)
If there are any YouTube videos that someone can point me to I would be so appreciative of the information.
Thanks in advance,
Mike
Thanks in advance,
Mike
