2000 Ski Centurion, 165 hours
Had to get towed in Sunday (my son's boat, mine is up north) after tubing for an hour then fishing for an hour (father's day present from my boys).Thought low fuel so we added 5 gallons in the middle of the lake, started fine, ran 100 yards and started sputtering and quit. Boat owning son said probably not low gas, has done this numerous times before.
Intermittent fuel issue, Occasionally starves for fuel even at idle. New filter installed last year by service tech trying to fix issue. I installed a pressure gauge today and at key on, it gets 30 psi, but as soon as the pump stops, pressure drops to 24 psi and holds fairly well, dropping less than 2 psi in 5 minutes. Idling it reads 22 psi. At a fast idle, pressure drops to 20 psi. From another older thread: "Manuel 24 states a fuel pressure of 30psi on 5C-2, but on page 5G-32 it states 34-38psi. What is correct?" Either way, fuel pressure is low. The hose at the top of the tank is tight, so it is not sucking air. (as it was on my LS Jeep a week ago) I pinched the fuel return line to the filter and the pressure at key on is still 30 psi. The vacuum line to the regulator is in good condition and not plugged. The quick drop from 30 to 24 hints that it might be a regulator problem? But refusal to go above 30 psi signals a possible pump issue. I don't want to just throw a $90 regulator or a $190 fuel pump at it. Your thoughts?
