James D. Evans
- Jul 16, 2013
- 37
84 Mercruiser 140...
Starts, idles, and will run perfectly fine for about 30 minutes, full throttle or part throttle, but then will start cutting out an back down to about 3500rpm, and continue to get worse till it won't run over 2000rpm. Will run fine up to 2000 rpm, anything more it just wont take. You can hear it in the exhaust cutting out. Even when it is acting up, you can shut it down, and it starts with the bump of the key, just won't run over 2000rpm. Does not shut down, die, etc, Have put a jumper wire to coil from battery, with no change in running condition. Anti-siphon valve removed with no change in how it runs either. Fuel pickup is clean and clear. Not overheating, runs about 140 degrees. No unusual noises, other than the exhaust when it starts acting up.
History on this boat.
Head replaced 11/2013. Points, condensor, and coil replaced this weekend. Sourced a ic14sb coil from Napa, which is a true 12 volt coil for points. Use them on old ford tractors as well, and I have 12 volts going to it, not using the resistor wire. Wires, plugs, dist cap, and rotor button replaced 10/13. Timing at 6 Btdc, and dwell at 30.4. Drained fuel tank, and installed all new filters, boat does have a water separating filter also. Running non ethanol, 87 octane fuel. Battery/Alternator good. Cleaned all grounds, and made sure the big plug was seated correctly and clean.
