havoc_squad
- Mar 5, 2011
- 705
1993 manufacture date
Alpha One Gen 2
3.0L
I am fairly certain that I have a bearing/pump issue with my Power Steering pump.
The fluid level was checked per Mercruiser specs on the fluid level with the power steering pump dipstick. It was within specs.
Description of issue:
The noise is not easily discernable during idle/low rpm, but when at 1500 it becomes more audible. So, I believe the noise with the pump is variable to the RPM speed.
To make sure, I put my ear right near the power steering pump and the noise was quite audible. On the opposite side I listened to the altenator and heard nothing, went close to the water pump and heard nothing on the right side of it.
Is there any other hints or helpful info not mentioned in the service manual that helps make 100% certain of a power steering pump issue, that would be appreciated.
Alpha One Gen 2
3.0L
