How hard is it to change the hose/line that runs from the transom to the drive? I remember when I had it winterized last fall the shop tech told me the line was starting to show some age and crack and I might want to think about changing it. Otherwise want to watch for leaking drive oil or a film on the water indicating it finally broke. I'm sure it would be a lot easier to change this fall if we pull the drive for service than to try and squeeze in there now.
The other question is, if I leave it and keep an eye on it. If it does crack and start to leak a little while its in the water the small positive pressure from the fill tank should keep water out correct, and like he said we would notice a oil film on the water surface.
