I have a 1983 mercruiser 3.0l serial number 4524932. The alternator doesn't seem to be doing anything. Battery voltage is the same with engine running or not and at any rpm. I looked in the service manual and from what I am seeing this isn't a stock alternator. There is the output wire, and then one other wire coming out of the back of it that is red. It wasn't hooked up to anything but had a male bullet connector on it. I also found a purple wire coming out of the harness y the alternator with a female bullet connector that wasn't plugged in. I checked and the purple wire has 12v to it. I tired connecting that to the red alternator wire, but made no difference. Any thoughts?
