cmarkham416
- May 14, 2014
- 3
I have a 7.4 liter and im trying to get the intake manifold off. I removed the risers and manifolds, as well as the intake manifold bolts and I still cant get it to budge. Any suggestions?
:welcome: to iboats
If you have all 16 bolts out it's probably just stuck. Many use an adhesive and can be quite stubborn. Do you have a cast aluminum or iron intake?
I have an iron intake.
Once the distributor is out, take a putty knife or big exacto and slice through the RTV seal on the fore and aft areas of the manifold. I know it's tempting, but don't wedge a screwdriver in there and pry on it. You can damage the sealing surfaces. The carb or TB and all cables must be disconnected as well.
