1989 Merc 4.3Lx OC534197
Alpha One OF162055
Last season I had problems shifting from forward to neutral to reverse.
My SternDrive is not install on the boat yet and want to verify both Lower and Upper Shift Cables adjustements.
And replaced them if needed.
Is it possible to check all cables adjustments, fonctionning properly without the drive install ?
I do have adjustments procedure, but it requires to turn the prop !!
Alpha One OF162055
