Re: mercruiser 4 cylinder 3.0 head vs 2.5 head
Depends on the year, but most 2.5L heads are different than 3.0L heads, "port configuration" wise. Some Mercruiser 3.0L engines used a 2.5L head (why, I don't know...), so depending on the year, a 3.0L head could be a direct swap for a 2.5L engine. Clear as mud, right? Mercruiser used 4-5 (6?) different heads on the 4 cyl engines over the years, so it's best to match up the ports,,, and valve sizes.
Larger valves and large ports are good for high RPM power and but bad for low RPM power, the exact opposite of what you want in a marine engine.
