Re: BRAVO lll OIL CHANGE
Thanks, I can't find anywhere in the Mercruiser Service manual that says after the oil comes out of the vent hole screw the plug in and keeppumping until it starts to fill the reservoir. Can't I just fill in the overflow bottle slowley until it gets to the fullline?
Re-read page 1b-11 in sm #28. I've extracted a few of the steps here, what does step 13 say?
11. Using lubricant pump, fill sterndrive unit through fill/drain hole with lubricant until oil is
even with bottom edge of vent hole.
12. Without removing lubricant pump fitting from fill/drain hole, reinstall oil vent plug and
sealing washer. Torque to 40 lb-in. (4.5 Nm).
13. Continue filling drive until there is one inch of oil in the gear lube monitor.
14. Remove lubricant pump fitting and quickly reinstall fill/drain plug and sealing washer.
NOTE: Drive oil will purge from square gear lube monitor if rubber seal is not in cap.
15. Fill gear lube monitor to FULL line on decal.
16. Ensure rubber seal is in place on gear lube monitor cap.
17. Install gear lube monitor cap.
IMPORTANT: Do NOT overtighten cap.
18. Check oil level in gear lube monitor.
19. Recheck oil level after first use.
MARK
