easyloader
- Apr 25, 2014
- 68
I installed the intake manifold of my 4.3 mercruiser. After I ran the motor for twenty minutes the a oil appeared from the rear gasket which the one where you have to use rtv silicone to from the gasket. I also noticed that the bolts where loose. I tightened them up and still had the leak. So I the then removed and reinstalled the manifold. Cleaning off all the surfaces and reforming the front and rear gaskets. Everything seemed ok until I took it out on the water and was running around three grand when the leaks appeared from the front and rear formed gaskets. The manifold bolts needed some tightening. I'm using permatex ultra blue gasket maker.
What am I doing wrong.
