karbine98
- Mar 17, 2014
- 29
Ready to reinstall MC-1 outdrive. Got gasket set with paper gasket for bellhousing, o-ring for water intake, and the larger rubber ring for the gearhousing. I can't tell from illustrations and the many videos I've watched where exactly I put that larger rubber ring. I know I am supposed to glue it in place. It seems to be larger in diameter than my gear housing. Do I glue it into the bellhousing opening itself or to the front of the gear housing onto that retaining nut. Hope I'm making enough sense for the experts on this great forum to figure out what I'm asking. Also hope I didn't tweak position of the prop and shifter rod when reassembling the upper and lower halves of outdrive. I only moved prop shaft in counter-clockwise direction after turning shift rod clockwise. I'll find out eventually. Thanks in advance, Greg
