Hi all, I bought a boat knowing it was damaged from an improper winterization (it bought very cheap). It has a 5.7 two barrel, boat is a 1996.I checked compression and number one is down to 60 psi, number two 110 psi, all the rest 150-165 psi. I took the manifolds and risers off and they look good with no visual cracks. Cylinder 4 and 5 had water in them. I want to preform a test on engine cooling system to see if it has any major leaks. Any advice as to how to do this?plug hoses and put air in or use a vacuum pump? Thanks
