TampaBoater
- Feb 23, 2012
- 207
So I had a thread about the alpha 1 drive not engaging in gears after pulling and replacing the drive, turned out the shoe and rod where not seated properly. Pulled the drive out with shift in full forward, like a poster mentioned. Pulled the drive, and re installed minding the shoe and rod. Drive went in nice and smooth....tightened everything down and started the motor......NOW...
Forward gear engages fine no problem. Reverse gear engages but an intermittent ratcheting sound is audible, and the normal ratcheting sound right before the gear engages is not present...What did I do wrong this time?
