Boat runs great for about 30 minutes . Then if starts missing bad . Sounds like one or more of the plugs isn't firing . Gets worse the longer it runs . If I cut it off and let it cool off it runs good again . Also I smell gas when this is happening . I figure that is the gas not getting burned because its missing so bad .
I replaced the points ,plugs,wires,rotor button and distributor cap at the end of last season .
Mt best guess is a faulty coil breaking down after it gets hot.
what do you guys think ?
