I have a 2001 3.0 Mercruiser 135HP. The motor was rebuilt last year and only has about 20 hours on it. The boat was winterized end of last year and kept in a garage. Took the boat out for the first time this weekend. Boat started up and ran great. Had the boat out for about an hour at trolling speed and then opened it up, not WOT but about 2/3. After about 10 minutes the boat just did not feel right, hesitating a little. Opened up the cover and saw oil all over the inside, coming from the valve cover to the flame arrestor. Oil was coming out of the corrugated hose coming from the valve cover to the arrestor (no PVC valve). Lowered the throttle and the oil stopped coming out. Oil pressure stayed around 35PSI. Brought the boat home, took off the arrestor and started the motor. Started right away and ran great. Could not hear any motor problems (tapping or knocking). I am going to do a compression test this week. My flame arrestor was also very clogged, I am cleaning that now. Lost about a quart of oil from the blow back.
Any thoughts or ideas would be appreciated.
