karbine98
- Mar 17, 2014
- 29
My first post for my first boat. Pulled sterndrive on my '78 Mercruiser 165 to check impeller and seals, etc. Wondered if the generic "Marine" grease is adequate for the u-joints and splines or only for the trailer wheel bearings. I'll have to drive a ways to get 2-4-C grease, but will if it is advisable. Also, I watched a video that said not to put o-ring on lower unit drive shaft since it will probably not stay in place when reassembling lower to upper and may mess up fluid flow. There wasn't one when I separated drive, but I did find a few pieces of an o-ring on the table later. This will undoubtedly be the first of many questions. Thanks in advance for any advice. Greg in Omaha
