Reverse lock valve
dozerII
Got a couple questions for the Pro's, I have a 1976 Mercruiser 120 motor #4479938, drive 4525102 and transom 572104
The trim pump was replaced by a P/O to the one in the pictures. Olydine.
First question is, with this pump do I need to use the reverse lock valve? I just did a complete rebuild on the boat and replaced all the hydraulic lines with high pressure.
If I don't need the reverse lock valve, big if, do I just join the two hoses that attach to the RLV? And do I just run the shift cables as they were to an inoperative valve?
Thanks in advance for ay help.
Re: Reverse lock valve
Ayuh,.... That pump just needs two lines run straight to the hyd. manifold under the transom housin',....
Delete/ ignore the reverse valve,...
dozerII
Your the man Bondo,Thanks, so I just run the shift cables the way they were on the RLV?
dozerII
One more question on this system, the P/O was running 10/30 in it I cleaned it our and refilled it with the same, is this acceptable or should I flush it and fill with ATF?
Thanks
Thanks
Ayuh,... Yer choice,... Merc has recommended both over the years,...
fishrdan
I did that conversion and Bondo is spot-on, just by-pass the RLV while leaving the shift cables connected to it.
One thing though, I filled the RLV with oil and capped it off, so the pivot of the assembly wasn't running dry while shifting.
dozerII
Thanks for the info.
