Captain Pauly
- Apr 22, 2014
- 7
I have an issue we have been chasing for a year and we are baffled. I have a 1994 Sea Ray 400 EC. It has twin 454's. The Starboard Carburetor will lose prime after sitting for a few days. The bowl in the carb is dry and the fuel separator is empty. There is no fuel or fuel odor in the bilge. We are convinced that the fuel is being drawn back to the tank somehow. I have to fill the separator with fuel and re-prime the carb and then engine starts fine and runs fine. If I start the engine everyday it has no problem, she fires right up and runs great. It takes a few days for it to drain back to the tank. I have replaced the fuel pump, the water pump (it drives the fuel pump), and the carburetor. We switched the fuel feed lines to rule out blockage in the pickup tubes and tank and have confirmed that there is no obstruction in the vent. We also pressure tested the fuel lines. There are no leaks in the lines. We are very baffled by the carb bowl being sucked dry. Any and all input is welcome we are out of ideas.
Thanks, Pauly
Thanks, Pauly
