Changing title to thread, see if it gets more hits............
I've been reading many threads on shift cable adjustments for Mercruiser Alpha outdrives. However, I have not seen any that have mentioned drives with Morse-Teleflex remote control cables. I have a 1992 4.3 liter that has this type of cable, or cables as they came together as an aftermarket package, throttle and control cables. This cable is red, and has a plastic barrel shaped thingy where there would normally be an adjustable brass barrel. This is the upper cable, or remote control cable. It is also equipped with a plastic shift assist assembly.
So my problem in going through the shift cable adjusment process is how are these cables adjusted? I have the bottom cable checked for excessive slop (only 3/8") and have adjusted to the 6" center to center dimension for the brass barrel and the hole on the end, have put back into place. I'm now ready to adjust the remote control cable. I've been told by one person that there's adjusment in the control box itself, but nothing specific in how.
Anyone out there that can help me with this, it is greatly appreciated.
Don
Don
