Starboard side hinge pin wont tighten
passngass
Hello,
I noticed today while working on my trim sender that there was some play in my alpha one 1st gen hinge pin. I pulled off the sender, got the special tool out and wentvto see if it was tight. Well it turned very easy, and never would get tight. If you wiggle the drive you can see the pin move and kinda back out a bit. All this wouldnt be a problem if the whole thing was old and it was time for new bellows and such. How last year in june the drive shaft ujoint broke and made a mess of the gimbal housing. I had all of it replaced, transome plate, bell housing bellows the whole nine. Now im having this problem.
I dontvwant but im about to drop the lower unit and pull the pin out andcsee what ihave. Either a broke pin, or a striped thread.?
My question would be does anyone know of a fix for this scenario? I.E. bigger hinge pin, some J.B. Weld or will i have to replace the gimbal ring? Or is there a draft that the pin screws into that could be replaced?
I thank you in advance for any and all help.
Michael
Re: Starboard side hinge pin wont tighten
Hello,
Michael
Ayuh,.... I'd suspect the problem is in the bell housin' not the ring, as that's where the threads are,......
All ya can do is take it apart to See what's bad,...
Then develop a plan,...
passngass
Thanks, yep that what i preparing myself for now. I will update soon
Thanks again
thumpar
Hopefully it is the pin itself and not the bellhousing but I doubt it. I am pretty sure the pin is a stronger metal than the bellhousing. I will cross my fingers for you though.
bspeth
You said you had everything replaced,was it by a boat shop or marina?If it turns out to be the housing you might want to ask them if they noticed this when the had the pins out. And ask them what they torqued the pins to.
Bt Doctur
Had housings get the threads ripped out removing a corroded pin .Never had a pin strip.The hole can be heli-arced closed some, drill and retap the thread
passngass
Update. Well it turns out it wasvthe bell housing. The threads are stripped out. At first i was going to just put J.B. Weld on the pin and let is sit overnight but thought about and decided that would be the half asscway to fix it. I dont want to be out on the water with half *** work to depend on.
Tomorrow im taking it to the local Marina and theyvare going to put a heli coil in it. Itll be done right and no need for worries out on the water.
Thanks for all your replies. You guys were spot on with what the problem was.
Hopefully thiscwill be the last surprise of this boat restoreration.....
