Hello all.
I have two 1997 Merc 5.7L 2 Barrel motors with Thunderbolt 5 ignition. Timing wise I have one dialed in nicely at around 8 degrees and advancing correctly to about 32-34 degrees at 3500 rpm's. The other one has been troublesome. When in Base Timing mode, I set it to 8 degrees at an idle of around 650. When I startup again out of base timing mode, the engine sounds fine...idles fine, but the timing is around 18 degrees. Furthermore, there is only about 5 to 8 degree advance in this state. Both engines have new caps and rotors and new plugs.
Yesterday I took the ignition module that is on the outside shaft of the distributor and swapped those. Problem stays with the engine. I then swapped the module that is inside the distributor. Problem stays with the engine. Even swapped coils... although I didn't really expect that to do much. Same result.
There is no knock sensor on this engine so it's not that. Also the amount of up and down play in the distributor shaft with the caps off between both distributors is the same... which is a very tiny bit...maybe a 1/16 of an inch.
Any ideas on what could be the cause? Both engines were run on muffs as I am not in the water yet.
Thanks,
--Rick
Thanks,
--Rick
