smassey22180
- Apr 15, 2013
- 210
I checked the factory service manual and am still unsure. I think I need to remove the shaft/u-joint/bearing assembly and then slide out the vertical gears. The question is can the lower seals be removed and re installed without removing the bearing at the bottom of the upper unit? Seals are changed from the top side correct? I would hate to do all of this if it was done from the bottom . Hopefully I have described this with the correct terms.
Also, Is it 1 seal or 2? It is 2 for the later serial numbers but may be 1 for my earlier one.
I removed and changed the upper oil seal last season along with the gimbal bearing and all bellows so hopefully this will go fast. Thanks
