sptjet90Reflexx
- May 28, 2011
- 383
Today I decided to replace my trim senders.. I did not get very far.
After removing the bell housing from the transom plate I disconnected the ujoint bellows from the bell housing and removed the screw holding the plate on for the sending wires. Plate was GLUED on it looks like.. I tried to remove it and it wouldnt budge so I used a long flat head and tapped it with a hammer. The plate split in 2. I still have not got the 2nd half off the boat.
What is the part number for that plate?
