I have a 2006 Bayliner with a Mercruiser 305 motor. The time has come to replace it. I have searched the forums here and it seems a pretty common recommendation to replace the 305 with a 350. However, in most threads, this conversion is done on older boats with carbureted fuel supply. It seems that the carburetor can be adjusted to supply the extra fuel for the 350.
My boat uses throttle body injection. Would I have fuel delivery problems if I switch to a 350? It seems like I would need some of the "electronics" in the fuel system replaced or reprogrammed to change the fuel supply.....which leads me to believe it would just be easier to stick with a 305 engine.
Anyone thoughts/recommendations would be greatly appreciated?
