steeler85048
- Jun 26, 2013
- 20
Hi all, I have been restoring a 1996 crownline 202 BR with a Chevy 5.7, thunderbolt V, serial 0F608827.
The previous owner water locked the engine and I decided to replace it with a chevy 5.7 vortec motor. I put a new water impeller in the outdrive I then re-installed the outdrive and installed all of the ingnition components.
I put a carbureted vortec intake on it with a marine quadrajet and all of the sensors and plugs mated up nicely. However, I have been having a problem trying to get it running. Initially when I first tried starting I noted that all of the plug wires from the distributor cap were on wrong. I then installed them correctly and it fired right off.
I hooked up the water muffs to the outdrive and ran it a little but the timing was off and it did not want to idle. I put a timing light on it and it was all over the place as far as timing goes. I tried to set the timing but got shocked when I tried to move the distributor. I then put all new plug wires on and it seemed to run smoother but I still did not get a good idle.
I then noticed that I had a gear oil leak from the water intake. I pulled the outdrive again and fixed a leaking seal carrier in the lower then pressure tested it and re-installed again.
I also noted that after looking thru the archives my battery was weak. I put two new batteries in as it is set up to run two and then tried to start it. This time I could not get it started. It acted as if it wanted to start but would backfire and diesel.
I checked the juice to the coil and noted that I had 12 volts...
My questions are as follows,
1) Could the ground with the second battery be worse?
2) Should I just junk the thunderbolt V ignition and go with the Delco Voyager set-up?
3) Suggestions on what to check tomorrow? I am going to check the tach to see if it's a problem and also will try to run on one battery, what else?
Thanks to everyone from a noob. Everything to this point has been pretty straight forward but electrical stuff is definitely not my forte...
Thanks in advance,
Philip
Thanks in advance,
Philip
