I have a 1999 Searay with a 5.7 Mercruiser MPI Magnum Bravo. Ran boat for about 40 miles doing 3100 rpm. All guages normal. Slowed boat down to fast or slow idle in a no wake zone for about 15 minutes, maybe 20 minutes. Then all of a sudden, engine just stopped. No warning. Tried to restart, will not even pop. Engine cranks just fine. Have spark so assumed fuel problem. Shot starting fluid and boat tries to start immediately. Since then I have replace numerous parts due to questionable appearance. These include fuel pump (only had 31psi), fuel/water seperator filter (did not have any water in it), TPS (when testing it was a little flukey and not smooth), Dist. Cap and rotor (highly corroded on the inside and cap had slight crack in the top), and the IAC (done on suggestion by friend). Doing something right because at least it will eventually start, but runs like crap and barely idles and smoke black like you cannot believe.
Engine always turns over well. Many times I can turn the key switch on, the fuel pump does not run. Leave key on or sometimes when I crank the engine, shut key off, and turn back on, fuel pump will start. Sometimes I can leave the key switch on and after 30 seconds or so, fuel pump will start to run. Only when I hear the fuel pump running will the engine start (with a lot of throttle). When it starts, it is exhausting black smoke, extremely rough running, and as soon as I bring the throttle to idle, it dies. Also, when it is running now, there is an alarm sounding. Alarm is just solid. Not a beep or anything. Just a straight monotone alarm. When it is running, and I try to throttle, it tries to gain RPM, but just so rough and just wants to die.
Anyone know how to check out the ECM? Or does anyone have any other ideas? I am all ears.
