Re: 1996 5.7l thunderbolt IV igition
Hi there, welcome to iboats! Have you verified that you have close to 12.6 volts throughout other engine points that utilize 12 volt power..... starting at the battery post then moving on to the battery cable connector at the battery then to the starter post, then cable post connector at starter, and continue upwards on the engine posts and wire connectors to see if they remain close to the same reading?
Also disconnect all the wires off of the coil and recheck the ones off of the + side for 12v power. Next as a test, leave the one gray wire disconnected that runs into the main wiring harness, it goes to the tachometer. If the gauge is shorted out, the engine will not start and could give you a false read as strong spark coming out of the coil.
Did you replace the distributor cap and rotor recently? Plug wire?
Pull the cap and look for moisture under it. Edit: try cleaning the cap with light sandpaper to see if it helps.
Good luck to you.
