Hi all, thanks for reading. I have a 1996 sea ray 19'. 4.3l with Alpha 1 leg.
I got it a year ago, runs great. Over last summer it seemed to develop a vibration when in gear. Couldn't tell for sure so I ran it for the season. Seemed fine, but still suspected something in the leg.
So getting ready for summer and fired it up in the driveway. There is a bit of noise/vibration, almost a slight clunk coming from the leg(in gear, forward and reverse) . Seems to be right under the upper cover.
Thought it might be ujoints, so have pulled the leg off. U joints look new, and no play that I can tell. The previous owner just had the bellows replaced, and it looks like the ujoints were also replaced or at least freshly greased.
So, there is a bearing right under the upper cover (held on by 4 bolts). Which does seem to have some play.
Just wondering if that could be the noise? And if so, how to pull it off?
Cheers,
Jason
Cheers,
Jason
